wolverine mods.
Old Sep 1, 1999 | 06:47 PM
downb4's Avatar
I have a 98 wolverine with a fmf performax pipe and k&n filter\jet kit.Does anybody know
of other mods I can make without flattening my wallet????
Old Sep 1, 1999 | 07:02 PM
mxer's Avatar
you shouldd read the warrior performanc post here, because the warrior and wolverine have basicly the sam engine.
Old Sep 2, 1999 | 10:23 AM
Harold's Avatar
Try taking off your air box cover and see if this helps, if so you can add another air intake and jet up one size,more air+more gas=more power.You can also install a torque stuffer to gain alittle bottom end.
Old Sep 3, 1999 | 12:37 AM
HERBERT C.'s Avatar
Harold, can a torque stuffer be used in conjuntion with a stock pipe? How do they cost?
http://community.webtv.net/murdo77/QuadzillaZone
Herbert~~99Wolverine & 89LT520
[This message has been edited by herbert c. (edited 09-02-1999).]
Old Sep 3, 1999 | 01:03 AM
downb4's Avatar
I have a torque stuffer,forgot to mention that.I was thinking of drilling some holes in the air box top,so you helped me make up my mind thanks Harold.
Old Sep 3, 1999 | 10:24 AM
Harold's Avatar
Yes, a torque stuffer can be used with a stock pipe it installs in the head pipe where bolts to the head, cost is $38.00.
Old Sep 3, 1999 | 10:30 AM
Harold's Avatar
hey dowmb4 you mightnot want to drill holes in your airbox lid depending apon where you ride, holes let in mud,dirt and water etc., a better solution would be to install another air intake beside your stock one,do a search under my name and you should see these mods.,if this new software allows a database.
Old Sep 5, 1999 | 10:06 AM
downb4's Avatar
yeah,I see your point about the mud and water
but I was thinking of putting some kind of thin foam pad on the under side of the lid to filter out the dirt as for the water I try
to stay out the deep stuff.Maybe I could put a bigger hole and run some type of breather hose.What do you think of that??
Old Sep 8, 1999 | 10:41 AM
Harold's Avatar
Thats the ticket, I made those mods to mine!!
Old Sep 8, 1999 | 06:49 PM
downb4's Avatar
thanks again Harold,you da man
suzuki230
Jul 8, 2016 10:03 AM
Kaleb_00
Jun 1, 2016 09:15 AM
JakeXBL
Sep 5, 2015 01:08 PM
Nelson
Jun 20, 2015 01:59 PM
thumper4x4
Jan 20, 2007 05:21 PM
