Warrior Jetting Question
Old Aug 16, 2001 | 10:05 PM
Atvsport400ex's Avatar
i have a 2001 warrior with a FmF pipe and i thought that i needed a new jet so i looks at the spark plug and it is pure white so i have a went and got a 150 but now i cant find the main jet in the Carbuator so where in the heck is it?????????????
2001 Blue Warrior
FmF Pipe
Holeshots front and back
Renthal Bars
AC front bumber
DG nerfs
Old Aug 17, 2001 | 08:38 AM
2001atv's Avatar
If you pull the 4 screws off the bottom of the carb that will let you pull off the bowl. The gold colored circle with a hole in it will be right in the middle of the carb and will have a slit in it for a flat head screw driver. Thats the main jet. If you go to www.troy-racing.com they have an online exploded view of the carb with each part # that will show you right were the main jet is.
Old Aug 18, 2001 | 02:28 AM
Blaster96's Avatar
Be sure to drain the gas out. Also be sure that the needle goes in the main jet hole. Do not over tighten or strip out.
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Reactant
Jul 16, 2015 10:29 PM
