RPMS
Old Sep 3, 1999 | 03:00 PM
Harold's Avatar
Does anyone knoe at what rpm the rev. limiter kicks in on a Wolverine and/or Timberwolf??? Guess I'll have to buy a Tiny Tach, Where can I order one from????
Old Sep 3, 1999 | 11:47 PM
boomer's Avatar
Hey Harold, I have had mine cranked up pretty good at times, and I dont think I ever hit the limiter. As far as the tiny tach.. Dennis Kirk has them, but only for a two-stoke. Wont work for us because the 2 fires every 180 degrees, compared to our 360. I did find a tach/ hour meter though but it didnt come in yet. Go to www.jackssmallengines.com and click the link on the left. I think I only paid about $38.00 for it. Plus its an hour meter too that also reminds you to perform maintenance every 25 hrs. When I get it and install, I will post it.
Boomer '99 Wolverine
Old Sep 4, 1999 | 07:01 PM
JRM's Avatar
JRM
I have a tiny Tach, model number 4962nr* I ordered it threw briggs and stratton at my small engine shop and it is for any single cyl 4 stroke $20.00. Found some intersting thigns about the rev limiter on bikes/quads, frist thing is when the limiter kickes in it cuts the spark as many times as needed to control the RPM, simply makes it a 8 cycle. when watching the tach on my 86'200SX it climbes steady past 5,900 rpm then right around 6,200 the tach instantly reads 4,000RPM showing it is cutting almost half the Spark in the engine to stop overrevving, I can still overrev another 10MPH out of it, you will be supprized how soon the spark cut is enguaged, barley noticable to even us mechanic's.
Joe
Old Sep 6, 1999 | 02:22 PM
thumper4x4's Avatar
Well for one the Wolverine does not have a rev limiter. Honda uses them alot, but not Yamaha. The RPM limit is because of the intake and exaust restriction. A new cam and port job, with exaust makes all the difference in the world. Mine hits about 8-9000 now...
Old Sep 6, 1999 | 11:38 PM
Blaster668's Avatar
Thumper, all machines have some type of a rev-limit. Yamaha uses a THORS system and all CDIs can only perform to a certain RPM so even if the machine could breathe correctly it be still limited by the built in limiter in the CDI.
Garrett Lowman; CT240 Blaster, YZ490
Old Sep 8, 1999 | 10:39 AM
Harold's Avatar
Thumper, my machines do have rev. limiters, I,ve been on both of them while doing some high speed riding on asphalt, thanks to all for your input on rpms.
Old Sep 16, 1999 | 11:18 PM
fastblast's Avatar
I believe the TORS system is used to cut RPMs if the throttle sticks , not limit them. I've had my Blaster revved wayyy out with a stuck throttle and air leak (yes both together, removed TORS). It kept going till I yanked the carb off. Any ways max RPM is less than max HP so it's not that important.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bigtwin700
Sep 10, 2015 10:46 PM
Steeldon
Sep 9, 2015 09:38 AM
