240 big bore
Old Aug 19, 2001 | 05:31 PM
blastaman94's Avatar
i have a 94 blaster and i was wonderin about the vitos 240 big bore kit. I thought that i have heard someone say they were junk. I was just wondering if it is worth the money and it does add some serious power. Do u have any other suggestions on big bore kits that maybve r better. Thanx for ur input
Old Aug 21, 2001 | 01:58 PM
TooQuicK's Avatar
Of course the big bore kit is worth the money if u want the extra power out of your blaster. Im sure the person u heard they are junk from has never even tried Vitos 240 kit. Call Vito and get some details from him. His number is 248-969-9168.
Old Aug 21, 2001 | 06:14 PM
BlasterWhodi's Avatar
I'm going to get a Vito's 240 kit over the winter. I did a lot of research on them and called them. It comes with a high comp. head gasket for use with 93, an L.A. sleeve, gaskets, a jet kit(i think),gaskets, and a Vito's 240 Power Piston. Best of all, the kit only costs $250, $160 more for installation. This kit made 30 hp on the Blaster that mobiledyno.com did their test on. My suggestions, get a timing key if you have a top-end pipe, get a K&n air filter or Uni Filter, get the ports polished by Vito, and, like any other big bore kit, get a bigger carb. Some say 30-35mm. You will get a ripping top-end but no low-end. I suggest a 28mm Keihin PWK. If you want he can also shave the head down for about 180lbs. of compression. But if you do that, get 50/50 racegas/93. Second to this kit would be the CT kit or the Trinity kit.
Old Aug 23, 2001 | 03:25 PM
raptorridah's Avatar
hey blasterwhodi how do u like ur trinity pipe?
Old Aug 24, 2001 | 10:05 AM
The pipe is GREAT. The top-end rips. Not too much low-end,l but the 240 kit should take care of that[img]i/expressions/face-icon-small-tongue.gif[/img]. Only problem is it rusts, so im gonna g et it coated.
Old Sep 1, 2001 | 11:11 PM
Daredevil1's Avatar
A well ported blaster motor will beat 240 blasters and you dont have to worry about overheating as much with the ported motors.
Old Sep 3, 2001 | 11:22 AM
jtblstr247's Avatar
I have a 2000 Blaster with Wiseco Pro-Lite Piston .40 over, FMF Pipe & Silencer, K&N air filter, Boyesen Rad Valve, Carbon Fiber Reeds,260 Main Jet,Holeshot XC's all around on Douglas .190 Rims with rienforcing rings, Renthal Bars, DG nerfs, AC sixpac Rack, and I can waste a Blaster 2000 Blaster with a 240 kit because i raced a guy that had one where i ride at, I can also stay side by side with a 400ex. So I guess you can say that 240 kits do suck.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
