turf tamers
Old Aug 21, 2001 | 12:43 AM
Vision's Avatar
what size is best in 18inch version the 18+9.5 or 18+11 or i should say what do you prefer
Old Aug 22, 2001 | 12:34 PM
raptorridah's Avatar
i run 18 9.5
Old Aug 22, 2001 | 05:58 PM
TitanRacing25's Avatar
wider is better, 18x11, it will grab more rut when you hit it and still get all teh wheelspin you need
Old Aug 23, 2001 | 01:03 PM
peterbilt's Avatar
I have used both the 9.5 and the 11's on my blaster at first I put the 9.5's on and they worked awsome especialy for an under powered machines like blasters but once I finished boring, portind, milling and all of the other trimmings I switched over to the 11's because I had enough power to use them, so basicaly if you have alot of power go with the 11's but if you are running stock power or want a tire that will spin easier than go for the 9.5 either way they both are good choices!
HondaMan85
May 26, 2001 03:53 PM
wcy2k400ex
Jan 31, 2001 08:56 PM
shollz
Jul 11, 2000 12:18 AM
novaman15
Apr 22, 2000 04:35 PM
RidE
Sep 27, 1999 01:05 AM
