question on dynojet kit for raptor
Old Aug 22, 2001 | 04:44 PM
Blur500HO's Avatar
For those of you who have the K&N Dynojet kit Stage 2 for the Raptor, do the main jets seem small. I believe the mains go from 136-150 in the kit. I have read many posts about Raptor jetting and most people are running between 155 and 180 mains. Is the kit a little lean or not a large enough range? For those of you who have the kit, how is it? Did you need to buy additional jets or did the machine run strong wit what was included? I am running a FMF powerbomb header, Supertrapp IDS2 silencer, and K&N Filtercharger in stock air box with flaps removed. I am at sea level. Thanks for your help.
Old Aug 22, 2001 | 04:51 PM
BansheeBrad's Avatar
I have the dyno jet kit.. the numbers on the main aren't standard.. so you can't compare them to what everyone else says.
I followed the directions to the letter and I am just about perfectly jetted. I used the full after market exhaust setting @ sea level (which happens to use the largest jets in the kit).
The one thing I did different from the kit, I installed 27.5 pilots, and I'm really happy I did.
Brad
PS.. I also used the aftermarket needles, I think they helped some.
Old Aug 22, 2001 | 05:30 PM
Joey9's Avatar
I also used the largest jets in the kit. The needles in the Dynojet kit have a different taper that's what makes them work so good. I got my jetting perfect the first time using the kit. I have an FMF slip-on,2.5" hole in the airbox + snorkle mod, and UNI filter.
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
