swing arm bolt???
Old Aug 25, 2001 | 09:20 PM
radchad's Avatar
hey everyone
i am taking my engine off right now...and i need to know how to get the swing arm bolt out????
please help....
also is there anything else i need to know before i take the engine off?? some advice?
thanx
Old Aug 26, 2001 | 02:11 AM
radchad's Avatar
anyone?
Old Aug 26, 2001 | 10:58 AM
atc86r's Avatar
what kind of quad? on my 250r i had to cut it off and replace what ever i destroyed. air impact and air hammer are the tools of choice but i had neither. they get stuck real good if not maintained properly. if its stuck real bad its probably time for new bearings or helm bushings. good luck this job can be very troublesome. when you do get it off put grease zerks on it. helm enterprises(in the back of dirt wheels) gives directions on how to install grease zerks.
Old Aug 26, 2001 | 02:19 PM
radchad's Avatar
my bad everyone
my quad is a 2000 400ex
i have all the engine mount bolts off.
all i need is the swing arm bolt, that goes through the swing arm and engine mount bolt.
do i unscrew it out or tap it out?/
thanx
Old Aug 26, 2001 | 05:19 PM
atc86r's Avatar
the bolt has lond smooth shaft with threads on last inch and half or so. unscrew nut then tap out.
Old Aug 26, 2001 | 05:28 PM
radchad's Avatar
wel i did my share of tapping today
so i took it to a mechcanic next door and he said he will heatit and get it out for me
i guess from the heat and grim. it is stuck pretty good
thanx
Old Aug 28, 2001 | 12:20 AM
K_Fulk's Avatar
when I took mine apart i used a punch and a big hammer and it came fairly easy. when i put it back together i put a bunch of neverseize on it incase i have to do it again.
Old Aug 28, 2001 | 11:51 PM
radchad's Avatar
my neighbor just told me that the bolt was broke in half. i guess the thing has been broken for a while. i had no clue.
he has got one side of the bolt out and is stil on the other side.
are these things common?? broken swing arm bolts?
Old Aug 29, 2001 | 01:33 AM
K_Fulk's Avatar
I dont know if its that common for them to break but Baldwin Motorsports makes a chromoly bolt thats supposed to be stronger. I put one in mine even though my original was still good.
Try Baldwinmotorsports.com
Joe454
Nov 20, 2020 01:19 PM
fd24
Jan 16, 2019 08:59 AM
EIF
Apr 20, 2017 07:15 PM
firsttimerider
Sep 20, 2015 09:07 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
