neutral light out
Old Aug 26, 2001 | 05:46 PM
01ds650's Avatar
Guys,
While riding at Silver Lake this past week-end my neutral indicator light went out. I figured all the bouncing around might have broke it.
I checked it out & found that there is not power getting to the light itself. If it's not the light, & the wires are OK where is the sensor that tells it that you are in neutral? Could that sensor be bad ?
Thanks....
Old Aug 27, 2001 | 03:13 PM
mintychip's Avatar
Your neutral safety switch could be bad. I just rebuilt my whole engine and I found that my switch had almost broken off. It's located right under the oil filter cover, you will see a small wire atteched to it with a small phillips head screw. If you so desire, you can cut off the end of it and not worry about a light, but you have to have the clutch in in order to start it, until you disable the lead itself somehow. Hope this helps.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Tim Shoe
Sep 7, 2015 12:15 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Pahuntman
Sep 5, 2015 11:07 AM
