starter on 400 scrambler 4x4 1999
Old Aug 29, 2001 | 08:51 PM
fmart's Avatar
This is my first post and not exactly sure if this is the place to put it but here i go. How hard is it to change the starter? Also what is the proper way to adjust the chain? Bought the bike used and didnt get a owners manual with it.
Old Aug 29, 2001 | 09:50 PM
Farmr123's Avatar
Changing the starter isn't too bad as long as you realize that there are 2 hidden bolts. To get to them, you have to take the side cover off the engine where the pull-start cord comes out of.
To set the chain, weight down the rear end (or use a ratchet strap from the axle up to the frame) until the front sprocket is level with the rear. There should be about a half inch of deflection, or a little more. Too tight causes more problems than too loose.
ghost civic
Jan 15, 2020 07:43 AM
neo27ny
Aug 24, 2015 02:02 AM
raceware
Jul 30, 2015 06:59 AM
kdg723
Jul 25, 2015 01:20 PM
