Sprockets
Old Aug 30, 2001 | 10:03 PM
Los's Avatar
Los
Anyone know what is the benefit of a larger front sprocket and a smaller rear sprocket?
Thanks
Old Aug 31, 2001 | 09:10 AM
puddding's Avatar
email me at my addy (under the profile menu)
and i send ya the gear ratio chart
pudding
Old Aug 31, 2001 | 12:18 PM
MEANGREENMACHINE's Avatar
You will gain more top speed and sacrifice low end.
Old Sep 1, 2001 | 12:06 PM
raptor720's Avatar
LOS,
Here is the deal on sprockets.
First, you never want to go smaller on the front if you can avoid it. I will only use a smaller front for a quick test. If it works, I make the difference using the stock front (or larger) and a different rear.
The reason why going to a smaller front is bad is because the chain is forced to change velocity at a much higher rate on the smaller sprocket. That is a power robber and a chain killer.
Most people just go with the smaller front because it is a cheap gear change but anyone who knows, will buy the chain and go with the rear.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
