250ex shocks on recon???
Well I dont have the recon anymore but here goes. The back bolts right up but you need to use a bushing with a smaller hole for the small bolts on the recon. And the fronts will not bolt up you need to make like a lowering kit for it I raised the location up 3 inches so it sat lower then stock in front and had awesome suspension. The ride was a bit smoother then stock out back and ALOT better up front but it really shined when jumping it. Good Luck, Zeebo
