250ex shocks on recon???
Old Sep 23, 2001 | 04:50 AM
yamahagye's Avatar
will the shocks off of the 250ex fit on the honda recon? since they have the same frame, it seems they would fit. thanks for your time/
laterz
Old Sep 23, 2001 | 10:17 AM
BK's Avatar
BK
They may or may not fit but you probably don't want to do it. They are VERY stiff. The extra travel sounds good, but I am 220 and I hardly move the atv when I sit on it. I am looking for softer springs right now.
Old Sep 23, 2001 | 11:51 AM
250rampage2's Avatar
Yea, about your only bet for better shocks on a recon are a set of works for about 550 (complete set). They increase travel too....
Old Sep 23, 2001 | 12:55 PM
KILLER250R's Avatar
If you blow the rear shock then it gives a really smooth ride! My rear shock blew on my recon and it road really nice and smooth. But then I replaced em with 300ex shocks. Good Luck.
Old Sep 24, 2001 | 07:46 PM
yamahagye's Avatar
KILLER250R
you put 300ex shocks on a recon? did they mount right up or did you have to modify the shock mounts? how do you like them? it sounds like you have a recon made for jumping.
Old Sep 24, 2001 | 07:56 PM
MasterOfDisaster's Avatar
ya the 250ex shock suck --- a lot!! i wonder if you could put 400ex shocks on them???
Old Sep 24, 2001 | 08:34 PM
KILLER250R's Avatar
Well I dont have the recon anymore but here goes. The back bolts right up but you need to use a bushing with a smaller hole for the small bolts on the recon. And the fronts will not bolt up you need to make like a lowering kit for it I raised the location up 3 inches so it sat lower then stock in front and had awesome suspension. The ride was a bit smoother then stock out back and ALOT better up front but it really shined when jumping it. Good Luck, Zeebo
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Jason Campbell
Sep 7, 2015 02:25 PM
