rubbing front tires?
Old Sep 26, 2001 | 12:56 AM
real4x4's Avatar
i have a 99 400 explorer and i have a set of 27/9.75/12 bi claws on stock wheels and the left tire is ok but the right tire still rubs after i shimmed it out as far as my studs allow.can i pop the studs out and get longer bolts or what?i also have the 27/13/10 tri claw on stock wheels but havent put them on yet.should i bother with using these tires or stay with stock meats?
Old Sep 26, 2001 | 03:48 PM
real4x4's Avatar
does anyone know this??
Old Sep 26, 2001 | 04:07 PM
cowboy's Avatar
Real4x4-
I don't know anything about your machine, but from the sounds of things, can you buy a set of wheel spacers??? I think they come with longer studs as well, so aside from sticking a couple inches wider up front, you'll have clearance to keep from rubbing-might that work for you??? If so, try highlifter.com-they should have it, or at least have a better idea to help you.
Best of Luck,
Mike
Reactant
Mar 30, 2022 02:08 AM
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
jettman
Jul 6, 2015 12:16 PM
