Scrambler 400 EGT readings HELP!!!!!!!!!!
Old Sep 27, 2001 | 09:28 PM
ScrambledKiwi's Avatar
I have just installed an EGT gauge on my modded 400 Scrambler 4x4, and would not have a clue as to what the correct tempature should be. I have heard that the max should be under 1250, but what is the optimum running tempature?
Can anyone help me please?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 28, 2001 | 01:19 AM
Xplor's Avatar
1250: maximum power temperature at WOT
1300: meltdown
1000: midrange (1/2 throttle)
800-900: 1/4 throttle
Thats what I have been lead to believe...
Old Sep 30, 2001 | 12:33 AM
Thanks Xplor
Any idea of when peak HP is reached - RPM v EGT?
Old Sep 30, 2001 | 10:00 AM
Ronnnnn's Avatar
Take alook at the back of the HPD catalog at the dyno graphs, if you built your bike with hpd stuff you can compare what you have to the graphs and see at what rpm you are achieving max hp if you are jetted and clutched correctly.
Old Oct 1, 2001 | 06:01 AM
Ronnnn
Most everything is HPD, but still having trouble finding the correct jettings for the 39PWK card, hence the EGT & RPM Gauge. I did not like the needle that the card came with from HPD, felt a bit lean, so went to a EEG on the middle setting. Feels a bit rich top and bottom now, but feel and actual can be very different! Don't want to another top end rebuild!
fordfaithful21
Dec 7, 2015 05:52 PM
1000gade
Sep 19, 2015 10:28 AM
1000gade
Sep 9, 2015 03:35 PM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
