adjusting works shocks?
Old Sep 28, 2001 | 12:04 AM
mudmanatv4x4's Avatar
can someone explain how i can change the preload on my front works shocks. they dont have resivors.
thank you
Old Sep 28, 2001 | 11:45 AM
dunner's Avatar
Does your shocks have threaded bodys if so just spin the nut with the spaner wrench up or down, if there not you have to send it back for revalving.
Old Sep 28, 2001 | 01:32 PM
AIRTIME88's Avatar
You don't have to send them in,if you want to adjust the pre-load you need to compress the springs(not the shock itself)there should be a circlip to take off that hold the spring, then you just re-install the circlip in one of the other grooves(up for more pre-load, down for less pre-load)you might want to try a strut spring compressor, you should be able to rent on of these from your local auto parts store for next to nothing. Hope this helps
Adam
Old Sep 29, 2001 | 12:25 PM
Sandgod's Avatar
Just have a buddy pull down the spring and then you use a small to medium flat blade screwdriver and just tap the end of the screwdriver on the clip in two or three places and presto it will snap into the next groove. Takes about a minute per side. No ****** pulling on the spring though.
Old Sep 30, 2001 | 12:22 AM
lakota00's Avatar
what i do is take a ratchet tie down and put it around the rack and the a arm than crank it down than take another tiedown and thread it thure all the springs than release the ratchet one and jack the quad up that makes the spring compressed and the shock extended and its real easy o move the c clip
2000 Lakota prm skid plate works dual rate front shocks surtrack backs
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Mphillips
Jun 26, 2015 03:52 PM
bucklove007
Jun 8, 2015 07:28 PM
blaze_master
May 26, 2015 11:18 AM
