HELP(Tires)!!
Old Sep 30, 2001 | 01:02 AM
02Raptor's Avatar
I need help with a Pair of Tires. Well I took off spyder track tires and Had to use a Bead Breaker well I only have one set of rims. Now I want to Put on a Pair of Turf Tamers and I cant get the Tire on the seal On one side. So what do I need to Do? Do I need any Special Tools?
Thanks,
Andrew
Old Sep 30, 2001 | 05:59 AM
woa's Avatar
woa
first remove the inner part of the valve stem so more air can flow through faster then use some sort of light oil and spread it around the tire where it should seal if you are still having problems use a rope around the tire and put it in the middle use a bar or something to tighten it. it should push the tire apart a bit.
Old Sep 30, 2001 | 11:21 AM
BansheeBrad's Avatar
Along with removing the stem to move more air..
Try taking a ratcheting strap around the middle of the tire and ratchet it tight. The pressure on the middle of the tire will push the beads out.
Old Sep 30, 2001 | 02:33 PM
DuneJammer's Avatar
Yes, special tools. A match and some starting fluid. Spray the starting spray (Ether) inside the tire and then throw a lit match into it. The lighter fluid will explode and when it's all said and done your tire will be firmly seated on the bead.
Old Sep 30, 2001 | 02:44 PM
The above trick works.. just stand back some when you throw the match, and wear some eye protection.. Ive seen to much ether cause a tire to shrapnel..
Brad
Old Sep 30, 2001 | 11:35 PM
chasman's Avatar
I wouldn't do the either trick either. I always take a 6 pack to the local dealer and get the guys to use their tire machine. Best $3.50 ever spent.
Old Sep 30, 2001 | 11:40 PM
02Raptor's Avatar
NOTHING WORKS. WELL THANKS FOR TRYING TO HELP![img]i/expressions/face-icon-small-smile.gif[/img]
I am just go to have a Gas station with one of those Tire roating. things. do it. well thanks again!!
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
