sportsman high idle-help!
Old Oct 6, 2001 | 11:25 PM
norton's Avatar
hi there
I recently did some work to my 98 sportsman 500 (steering bushings)
after I got it all back together and started it up-it now idles extremely high. sounds about half throttle-cant even put it in gear without clashing.
The only thing I did different that I know of in regards to the fuel circuit is that I dumped some fuel stabilizer in the tank when I went to refill it.
Any one have any suggestions???
thanks alot
fran
Old Oct 7, 2001 | 01:04 AM
OffRder15's Avatar
Did you check your throtle cable? See if there could be (maybe) a kink, or try adjusting it.
Old Oct 7, 2001 | 10:08 AM
biggy's Avatar
sounds like you pulled or misplace your throttle cable , when installing the bushings . try and pull on the cable when its running? any differance? if the idle changes you need to reroute that cable !!!! good luck
Old Oct 7, 2001 | 03:45 PM
norton's Avatar
thanks guys
I found the gas tank had wedged the throttle cable between the frame
I still did need to adjust the cable though(add more freeplay to the thumb trigger) in order to bring the idle down where it finally should be????? I figured once the cable was unkinked that alone should have fixed it? oh well!
thanks again for your responses
Jmuddin284
Jan 19, 2026 07:16 AM
ltrmc02
Jul 22, 2015 04:50 AM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
MNatv89
Jul 7, 2015 11:36 AM
