stalling under high G
Old Oct 8, 2001 | 10:30 AM
1rap's Avatar
I am having a problem with my raptor stalling under high G's, like a fast 360, after heavy hill climb, and when I am at a steep vertical. the bike will run great, and then acts like its not getting gas at the low end, if I blip the clutch and let it rev up it goes away. anyone have any suggestions?
I tore my carb down and cant find any problems, I have a dynojet kit aftermarket air filter and exhaust sytem
Old Oct 8, 2001 | 05:31 PM
Backcountry's Avatar
The fuel can potentially be sloshed to one side of the float bowl under a high load turn and the engine momentarily stalls for a lack of fuel. When you pull in the clutch the load decreases, the engine is able to recover and off you go....
As for fixes....dont ride so hard!!!! Must be a bummer of a problem to have....LOL...
I am not sure what is available that would work. For some of the bigger 2 stroke Keihin carbs there are larger float bowls to help with similar problems...
Old Oct 9, 2001 | 11:14 AM
raptor720's Avatar
1. too lean
2. float level too low
Pehter
Oct 3, 2024 11:00 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
