Starting Raptor other than in neutral
My parking brake was removed when my swingarm was extended. Now my Raptor only starts when in neutral. Is there an easy fix so I can start it with just the clutch pulled?
Thanks for your help!!!!
P.S. I have had my Raptor a year now with no Tranny problems!
If you really want to clean up the look and keep the clutch switch in place then buy the left brake perch for a Kodiak. Also buy a brake block off plate. Then you can get rid of the stock perch, rubber boot, and the emergency brake cable. You can reuse the stock clutch cable or buy the break lever that goes with the Kodiak brake perch.
/NotuRaptor
/NotuRaptor
