Starting Raptor other than in neutral
If you really want to clean up the look and keep the clutch switch in place then buy the left brake perch for a Kodiak. Also buy a brake block off plate. Then you can get rid of the stock perch, rubber boot, and the emergency brake cable. You can reuse the stock clutch cable or buy the break lever that goes with the Kodiak brake perch.
/NotuRaptor
/NotuRaptor
