Can I still ride with a torn boot
Old Oct 11, 2001 | 07:56 PM
500DUSE's Avatar
How hard is it to replace the rear boot on my SP?
I was greeseing it up when I found it.
I had a ride planned this weekend.
Am I still going ?
TIA
Old Oct 11, 2001 | 08:47 PM
cowboy's Avatar
Boots are fairly easy to replace, shouldn't take more than a half hour-45 minutes at most. Probably around $20 for the boot kit. The funny thing is, a Yamaha dealer said that with atv's, you can ride with a torn cv boot through all terrain for short periods of time-like a day or two if need be and not worry about doing any damage. I thought this sounded pretty strange myself-either he was trying to persuade someone to do this, hoping it would cause damage and he could sell a cv kit, or he was telling the truth, it's hard to say. At any rate, will you be riding in very much mud and water? GrizRick tore a front cv boot on our last ride in very dusty, rocky conditions, had grease spewing everywhere. We took a ziploc gallon freezer bag, cut it down both sides, then wrapped that around the boot and axle itself, then used some waterproof first aid tape I had in my bag to tape it up good. It was crude, but you know what-it worked! We rode probably close to 50 miles after the fix using that ziploc bag trick and it worked great-didn't have a single problem at all, ever. Granted, he did get a new boot when he got home, but we were in some pretty rough terrain that required a lot of winching as well for both of us, the boot and cv did fine. I don't know that I would recommend driving in a ton of water with this fix, but it might work OK for small crossings and such till you can take the time to get a new boot.
If it's a small tear and you still have most of the grease, you can probably get away doing something similar to still allow you to ride, but I would get it changed as soon as possible after that. If the tear his big and most of the grease is gone-I think I'd be on the safe side and just replace it before you go.
Best of Luck,
Mike
soggyrider's Avatar
If you are talking about a cv boot I would not recomend riding until you fix it. Doing so would get dirt into the joint causing it to wear out. Replace the boot, or you will be replacing the whole joint.
Old Oct 11, 2001 | 08:53 PM
DieselPro's Avatar
As Red Green would say "duct tape!"
So long as you keep out of water...
Personally, I'd replace it. As stated earlier, not too difficult.
Old Oct 11, 2001 | 09:05 PM
500DUSE's Avatar
I was just reading some of the replys from a search on cv boots ,
and it dosent sound to bad.
I'll give SLAPPY(my parts guy)a call tomorrow and see if they have it in stock.
If not, is there a some other place to get it,Highlifter dosent have it?And is there a better one,I was reading about a kevlar one???
Its ripped up pretty good so unless I came up with the boot
I wont be rideing that one
Old Oct 11, 2001 | 09:18 PM
TheGhost's Avatar
No do not ride your bike!
Change the boot asap!
They are cheap...
1999 sportsman 500 1000miles
Old Oct 12, 2001 | 06:44 AM
Stretcher's Avatar
500DUSE,
Don't even consider riding 'till you fix it, your local dealer should stock the boots and it is an easy fix!
BTW, where in NJ are you ?
Old Oct 12, 2001 | 07:02 AM
500DUSE's Avatar
Stretcher
Yeah after I read some old post I figured it
wouldent be the smartest move.
As for the dealer stocking it......
My Dealer is a nitwit[img]i/expressions/face-icon-small-disgusted.gif[/img]
I'm down in S.Jersey
outside of atlantic city
Old Oct 12, 2001 | 09:09 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
DieselPro
How do you like the 589s?
Good on all types of terrain?
Good ride?
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Mphillips
Jul 2, 2015 07:20 PM
