K&N power kits?
Old Oct 16, 2001 | 12:35 AM
polarisisthebest's Avatar
I am thinking about getting a power kit for my four wheeler and i am wondering if it is worth it. They come with an air filter, outwear, needles and jetting. If you know, what is the average MPH gain from a power kit just on average for any four wheeler. Also i wanted to know if it is hard to install the jetting. thanx for any help![img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 16, 2001 | 12:34 PM
Holty's Avatar
The K&N filter and outerwear alone are worth the money. They make great filters! Also, jet kit will add some more power, but I don't know any exact specs, sorry. I own a Yamaha Warrior, so I don't know much about Polaris and how hard it would be to install the jets.
Old Oct 16, 2001 | 01:07 PM
Dill's Avatar
in short, no. Just buy the filter and jet the machine correctly.
See this thread Jetkit Hooplah
Old Oct 16, 2001 | 03:29 PM
OhioScrambler's Avatar
Put a jet kit on my Scram. I guess I really have not noticed much. You have to take all the plastic and the gas tank off to get to the carb. Took me about 2 hours to do it. I think once i get a pipe and clutch kit i will notice more.
Old Oct 17, 2001 | 09:46 PM
gaff's Avatar
I have installed jet kits up the gazzoo.
Out of all I have done I believe the needle alone is worth it.
What you get is improved air fuel mixture adjustment over stalk (0-25% throttle) A new needle wich graetly improves mid range (25-75% throttle) and sized main jets depending on mods and altittude (75-100% throttle)
In some kits for constant valocity carbs you will recieve a drill bit to drill the slide lift hole larger to increase slide speed.
Of course these kits are developed around K&N filters and after market pipes, but in all cases throttle response is graetly increased.
As for top end speeds, don't expect much if any. As far as power across the rpm range expect gains.
If I was to guess top speed gain with a pipe and filter included I would gues two to three mph on average on a broad amount of bikes
Hope this helps, I'm not trying to be a smart --- just trying to help!
Oh yes, the kits include a 800# and instructions that are for do it your selfers
Cantbuytime
Aug 17, 2015 06:33 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
toonces
Aug 5, 2015 05:55 PM
ghost civic
Jul 27, 2015 03:15 AM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
