trailblazer chain adj. NEED HELP!
Old Oct 16, 2001 | 10:49 AM
mster's Avatar
how do you adj. the chain on a 2001 trailblazer???
my manual (sucks) shows a technique (loosen caliper mounting bolts and the two large bolts that hold the rear axil in place and then put a pin through the sproket into somthing?)but it does not jive with my bike. can any one help out???
thanks
Old Oct 16, 2001 | 05:09 PM
OffRder15's Avatar
Loosen the eccentric bolts on the axle housing and the bolts for the caliper mount(on the under side of the axle.) After that's all loose, I like to use a giant pair of channel locks to rotate the axle housing (forward is tight, rearward is loosen.) After it's adjusted to the proper deflection, tighten everything back up and RIDE!!!
Old Oct 16, 2001 | 05:56 PM
jmoney45's Avatar
After you have the two bolts loose that hold the axle bearing housing in place, you have 2 choices. You can rotate the housing like Offrder15 said, or you can put a pin (I have used a screwdriver) through the sprocket and line it up with a hole in the swingarm and then roll the quad. This is essentially another way to rotate the housing.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
chewy78
Sep 8, 2015 10:37 AM
bmark0610
Sep 7, 2015 09:42 PM
