nuts on the axle
Old Oct 20, 2001 | 12:16 AM
redjosh's Avatar
hello i am tring to fix the baerings in my rear axle houseing and i can't get on of the nuts loose we have broke a monkey wrench tring so any one got any suggestion please
Old Oct 20, 2001 | 12:22 AM
real4x4's Avatar
what kind of atv?
Old Oct 20, 2001 | 12:41 AM
redjosh's Avatar
it is a trail blazer 2000
Old Oct 20, 2001 | 03:28 AM
modquad's Avatar
Redjosh,
On the right side, that's chain and sproket side. Remove the snap ring, lock sleeve, and foam seal from the axle. Remove the sprocker hub nut, it's only 8-10 ft./lbs...this is on the right side. Remove the brake caliper (support w/zip tie, or safety wire). Slide the axle assembly out the left side. Forgot one step....loosen the chain. If you totally disassemble the axle, there is a groove on the left side of the axle between the LH splines and the LH axle nut threads. To service the rear hub, you should save hassles, and only disassemble the RH side. The 8-10 ft/lbs of torque on the RH nut need to be augmented w/ Loctite 262. The LH nut is 120ft/lbs= Lots'O'wheaties.
Good Luck,
Ken
Old Oct 20, 2001 | 01:08 PM
MEANGREENMACHINE's Avatar
If that doesn't work and you still can't get the nut loose. Get a chisel and hammer and put a notch in the nut. Then hit the chisel or punch with a hammer and it will free it up.
Old Oct 22, 2001 | 12:42 AM
redjosh's Avatar
ok so how do i get to both bearing from the right side with out gettting the left off
Old Oct 23, 2001 | 02:15 AM
modquad's Avatar
Redjosh, with those other components removed w/ the RH wheel and hub removed, you slide the axle out of the carrier on the left side.....I'm going to get on a soapbox now. Please don't take offense Redjosh, but the cost of a service manual is about the same as replacing that pipe-wrench you broke. We are here to help you, but the manual can save you a lot of grief....and $$$$$ More performance parts for your quad!!! Besides that, sometimes the pics in the manuals help put the technical mumbo jumbo in the light. Good luck!!!!
KT
Old Oct 24, 2001 | 12:56 AM
redjosh's Avatar
hey thanks don't worry about the soap box as far as i am consinered you could of just said go buy the d!mn manual i truthfully never though of that thanks alot
Old Oct 24, 2001 | 03:51 AM
modquad's Avatar
You are very welcome. We are all learning on these things every day.
KT
Old Oct 24, 2001 | 10:20 AM
Farmr123's Avatar
The Polaris website has links to parts manuals online. If you download the one for your machine, it will have exploded diagrams that show you how all the parts fit together.
Still it is no replacement for a service manual.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
raman8tor
Sep 20, 2015 07:35 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
