Where is the vin number on a '95 polaris Magnum located?
Old Oct 22, 2001 | 01:59 PM
hrc200x's Avatar
In the manual it says the number is located on the left side of the frame by the oil tank, I looked and didn't see it. On the right side of the frame is a number but it isn't a vin number. Is the vin number scratched into the frame or is it a sticker?
Thanks
Old Oct 22, 2001 | 05:19 PM
MagnumMudMan's Avatar
hrc
On my 98 Magnum, the VIN number is etched into the frame on the left side between the a arm and the oil tank mounting bolts. Take a rag and spray WD 40 on it and wipe the frame clean. You should then see the VIN number etched into the frame. Mine also has a sticker under the top headlight that has it on. Hope this helps.
Old Oct 24, 2001 | 11:19 AM
hrc200x's Avatar
I told my dad to look there and nothing was found. He also called a dealer and they said to look under the seat on the frame and by the headlights, and still nothing. I need more ideas. Thanks
Old Oct 26, 2001 | 02:27 PM
WJW's Avatar
WJW
On the 1996 I have here it is on the right frame up high behind the front tire in front of the shifter box, Look in between the tire and front fender
WJW
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 13, 2015 05:11 PM
Shifts
14
Jul 13, 2015 08:41 AM
jettman
Jul 6, 2015 12:16 PM
