CHAIN?
Old Oct 28, 2001 | 01:05 AM
bermbanger400's Avatar
does anyone else have a problem keeping there chain tight on there scrambler i can tighten mine then after riding all day(i jump mine alot) its loose as hell. i have tried everything. will the roller that hpd sells help me out?
Old Oct 28, 2001 | 10:23 AM
x_scrambler3's Avatar
I think it will help you out my friend has it an it works good
Old Oct 28, 2001 | 07:20 PM
midnightxplorer's Avatar
On my xplorer i have too keep checking mime too its a pain. mine a 97 poor set up but just make sure the 2 back bolts are tight and go by the spec in the manual...
Old Oct 28, 2001 | 07:24 PM
500SCR's Avatar
I had the same problem on my 99 Scrambler. I changed the chain and sprockets and the problem went away. Do you have alot of time on your chain and sprockets? If you do, I would suggest changing them.
Scott [img]i/expressions/face-icon-small-cool.gif[/img]
Old Oct 28, 2001 | 08:23 PM
tks guys i am going to get the tensioner from hpd plus put new chain and sprockets on it probably go with sidewinder.
Old Oct 30, 2001 | 08:27 PM
polarisrules44's Avatar
i would buy a chain tensioner ,,i put one on mine and my chain hasnt come loose yet ...hope it helps.
Old Nov 2, 2001 | 04:27 PM
jondeer78's Avatar
From my experience, which may be worth a nickel, sometimes if you tighten the chain too much it will actually stretch when you ride. (especially if it is old and not lubed well). Be sure to give yourself a half inch of play after tightening when you (the rider) is sitting on the quad. My friend has a 98 Trail Blazer, which is before they changed to the egocentric drive system.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
