Compression Readings
Old Oct 30, 2001 | 03:51 PM
ScrambledKiwi's Avatar
Hello.
Can anyone tell me what the compression readings for a 400 Scrambler should be. I tested mine last night after some problems in the weekend, and get 115psi. Is this normal? Help!!
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 30, 2001 | 04:12 PM
truck's Avatar
115 psi is good enough for it to run.
Old Oct 30, 2001 | 04:28 PM
walexa's Avatar
In the service manual, 115 psi is the service limit........in other words, it's time to rebuild.
Old Oct 30, 2001 | 05:03 PM
*****. I rebuilt it 10 hours ago. This will be the third rebuild this year. Thanks guys.
[img]i/expressions/face-icon-small-sad.gif[/img]
Old Oct 30, 2001 | 05:06 PM
Any idea of what it should be after a rebuild?
Old Oct 30, 2001 | 05:16 PM
DaveB's Avatar
Compression changes with elevation. If 115 lbs is the service limit, I assume that is sea level. If you live at 3500 feet, that will be down to about 105 lbs. This is why we shave the heads for high altitude.
Old Oct 30, 2001 | 05:30 PM
Yep, I am at sea level most of the time. I had problems in the weekend with the belt and starter, and was at 5000ft then.
fordfaithful21
Dec 7, 2015 05:52 PM
atvcollector
Sep 8, 2015 05:11 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
Mphillips
Jul 2, 2015 07:20 PM
