Please help me with this problem.
Old Nov 1, 2001 | 08:31 PM
Sportax300EX's Avatar
I was out in my garage today checking over my 300ex, when i discovred a little problem. Where the top A-arm bolts down through the metal bracket by the tire, there is a rubber thing inbetween the bracket and the end of the a-arm where the bolt goes down through. i think it is a seal of some sort. Well there is a large hole in it where something was rubbing on it and wore it through. Now do i have to replace that and does anybody know how much it will cost?
Old Nov 1, 2001 | 10:08 PM
KNOWSALOT's Avatar
The Facility
I assume that what you are refering to by your description would be the ball joint. If you still have the OEM Honda a arms, you will have to buy a complete a frame to replace it. They are not available seperately. However the problem you have is easily fixed by wrapping electrical tape[black] around the rubber part only and no one will even notice it. Just make sure that you put some grease up in there before you do it. You may have to go back and repair it again every couple of months or so, but considering what an a frame costs, it's worth the effort.
Old Nov 1, 2001 | 10:35 PM
lonestarbanshee's Avatar
Or you could just buy a replacment A-Arm....
Beeline08
Nov 11, 2016 04:00 PM
shimanok2
Jan 29, 2016 07:37 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
