Are A-arms interchangeable between Baja and Original DS??
Old Nov 3, 2001 | 01:39 AM
DSONYX99's Avatar
I'm sure other owners of the MkI DS (1st make) would also like to know the answer to this question.
Apparently, some of you own, or have seen the new DS. All the new stuff takes a while to get here where I live.
I would like to know what changes have been made to the a-arms on the Baja?? The only info I can can find is from the photos; and all that the magazines say is that the new arms are "improved". If the new a-arms are better, can they be put on an original DS??
All responses are appreciated! Thanks.
Old Nov 3, 2001 | 09:43 AM
99500scrambler's Avatar
It would be nice if they where. I dont know though. I'll check on monday, my dealer has one on the floor so he should have the parts list as well. It would be nice if they are cheaper than aftermarket ones. But if they are then will they be as good?
Old Nov 3, 2001 | 10:51 AM
CALDS650's Avatar
Here are the part # numbers and prices I got from Parker Yamaha
http://www.parkeryamaha.com
Part1: A-arms upper and lower both sides
> Part2: all Ball joints
> Part3: RH upper # 706-200-246 = 68.69
> Part4: LH upper # 706-200-252 = 68.69
> Part5: RH lower # 706-200-257 = 99.54
> Part6: LH lower # 706-200-264 = 101.02
> Part7: Ball joint x 4 # 703-500-082 = 135.10 each.
> Part8: Parts are back ordered
Old Nov 4, 2001 | 12:54 AM
DSONYX99's Avatar
Sorry I couln't find those parts anywhere on the web site. Did you have to email them for prices? I'm assuming this means the a-arms are interchangable.
Also, are the ball joints 135.10 each??!! Or is that $135.10 for all four?
Thanks so much for the time and info!!
Old Nov 4, 2001 | 06:18 AM
CALDS650's Avatar
I e-mail them and it is $135 ea. I am still trying to find out if the A-arms are interchangeable
Old Nov 4, 2001 | 06:50 AM
DS650DAVE's Avatar
I bet they are interchangeable,
if they say they are not,this means there are two different frames (&amp[img]i/expressions/face-icon-small-wink.gif[/img]or different spindles & that does not seem too
likely.
It would seem to be a good set-up to have the Baja lower A-arms & adjustable uppers(aftermarket) to acheive a an awesome front end set-up.
Old Nov 4, 2001 | 12:11 PM
fourlix's Avatar
I already have the TimmyBoy uppers,,,,Adding the Baja lowers would be sweet, should save some weight....[img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 4, 2001 | 01:04 PM
CALDS650's Avatar
Stay tuned Timmy is working on new lowers I should have more info later this week
Old Nov 4, 2001 | 05:47 PM
fourlix's Avatar
Timmy Boy lowers to go with the uppers I already have, plus a minus one inch swingarm. That could be verry nice.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 4, 2001 | 10:32 PM
DSONYX99's Avatar
Can I use the ball joints from my DS? Or are they unusable once removed?
I guess one thing I've never done on a quad is replace A-arms before. Is it more difficult than replacing rear axle bearings (which I have done)?
Thanks again for the responses!
