Cool Head ?
Old Nov 8, 2001 | 09:31 AM
boxcars4's Avatar
If you buy a Pro design cool head do you need to do anything to the cylinder? Is there a different head gasket? Thanks
Old Nov 8, 2001 | 11:01 AM
retro's Avatar
No you should not have to do anything to the cylinder. You can get o-ringed and not o-ringed cool heads and also w/headstay or w/o.
ERIC
Old Nov 8, 2001 | 11:07 AM
boxcars4's Avatar
can you give me a little more detail. I understand the head stay deal. But the o-ring head I don't understand. Is it a o-ring head gasket? Or the o-ring on the dome? What has to be done if you have a o-ring cool head?
thanks
Old Nov 8, 2001 | 11:43 AM
retro's Avatar
You don't have to do anything to the cylinder. You can get the head that used 2 o-rings as a head gasket or just a normal head that uses a normal head gasket.
I have the normal head with 21cc dome and thin CR style head gasket and I have 210 lbs compression and run a 50:50 race gas.
ERIC
Old Nov 8, 2001 | 05:49 PM
boxcars4's Avatar
I read on the LRD site that "O-ring grooves are cut into the top of the cylinder instead of using old fashion head gaskets like every body else" Any suggestions?
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
poutlaw525
Sep 9, 2015 03:19 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
lancemll88
Sep 5, 2015 03:16 AM
