Does a Rubicon have a better ride than a 450ES?
Old Nov 20, 2001 | 11:27 AM
westport's Avatar
I just sold my 450ES. It was a strong running go anywhere machine, but the harsh ride and heavy steering was too much for me (call me wimpy) on the all day rides.
I was looking for a smoother ride and was wondering about the Rubicon. According to Honda it has around an inch more suspension travel front a rear. I was curious from guys who have riden both. Does it have a better ride and is the steering any light with the differnet diff. in the front?
Also, does have a plan to make a 2wd/4wd switch for the Ruby like the new 450's?
Old Nov 20, 2001 | 12:07 PM
TEXMud's Avatar
It does ride better and the steering is much easier. I was surpised to see how heavy the 450 steering was. I assume in 2003 the Rubicons will have a 2wd switch, but I havent heard anything.
Old Nov 20, 2001 | 03:07 PM
JRM's Avatar
JRM
one word, Rincon!
Old Nov 20, 2001 | 03:13 PM
westport's Avatar
I been looking at the Rincon on the Honda website, but I don't care much for the way the front end looks like a spaceship.
The independent rear suspension sounds good though.
Re: the switchable 2wd/4wd mode of the Rubicon, I did see on Highlifters website that they offer a kit to convert a older 450 Honda to allow to use 2wd and a kit for the Ruby is coming soon.
Old Nov 20, 2001 | 04:12 PM
trx450's Avatar
I would agree with TexMud, the Ruby has a "plusher" suspension and it DOES steer with less effort. Don't understand the steering effort difference as the two share all the same suspension components(unless I am badly mistaken)! I ride a 450-S, but hop on a Ruby once in a while.
Old Nov 20, 2001 | 04:59 PM
Honda445EX's Avatar
I ride both all the time and the rubicon rides smoother and turns easier.The rubicon that i ride has mudzillas on it and suprisingly those tires make it even easier to turn!
Old Nov 20, 2001 | 09:20 PM
douglasss's Avatar
I am not sure about the U.S. Machine vers the Canadian one but I ride both machines and definitly find that the 450 has a better ride then the Ruby.The back is ok but I changed the fronts because I found it way to hard and also these are adjustable!!!And there is also a big diffence in the steering I think.(The Ruby is lighter)
Old Nov 20, 2001 | 09:31 PM
Elrancho's Avatar
The rubicon has a better front differential than the 450s, it has no clutches inside, the "unloaded" torque to slip the rubi/rancher differential is about 13 ft pounds. The function of the rubi/rancher diff is rediculously hard to explain, as there are no gears in it either, just cams and followers.[except for the ring/pinion]
Old Nov 21, 2001 | 01:37 AM
JRM's Avatar
JRM
its the same design as ford used in some of there trucks in the 70's, It is pretty much a open diff until one wheel spins faster.... then it is enguaged by the driveline.
Old Nov 21, 2001 | 11:42 AM
RubiconBob's Avatar
Actually, the Rubi/Ruby diff is a copy of the new Jeep design from their Grand Cherokee...
Nondem
Feb 22, 2020 12:20 PM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
