warrior motor mount keeps breaking
I used to have a warrior that kept breaking the rear mounting bolt. We found that sometime in it's past that the engine mounts had been allowed to come loose and had been ridden like that for awhile, the bolt holes and cases where worn, the result was that even though tightened to the nth degree they kept breaking as thing could move around , the chain puts allot of torque on the engine under drive load. We drilled the mounts out from a metric to the next size up fractional sizing and instaled SS bolts, no more problems. A big job and you will need over length drill bits etc, not for the faint hearted........
Kiwi
Kiwi
