warrior motor mount keeps breaking
Old Dec 4, 2001 | 07:41 PM
ferd350CT's Avatar
Anyone else having this same problem?Third upper motor mount this year.I rarely jump her,and dont ride her much.Can I get a stronger mounts?
Old Dec 5, 2001 | 07:11 PM
dominatingwarrior's Avatar
The motor mounts wrer broken on my 2000 when I bought it, but so far the mounts on my 2001 are still holding up and I jump it a lot.
Old Dec 5, 2001 | 07:40 PM
54warrior's Avatar
Just keep checking them to be sure they are tight, and you shouldn't have that problem.
Old Dec 7, 2001 | 08:28 PM
Kiwi_Craig's Avatar
I used to have a warrior that kept breaking the rear mounting bolt. We found that sometime in it's past that the engine mounts had been allowed to come loose and had been ridden like that for awhile, the bolt holes and cases where worn, the result was that even though tightened to the nth degree they kept breaking as thing could move around , the chain puts allot of torque on the engine under drive load. We drilled the mounts out from a metric to the next size up fractional sizing and instaled SS bolts, no more problems. A big job and you will need over length drill bits etc, not for the faint hearted........
Kiwi
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
