WILL 300EX RIMS FIT ON WARRIOR HUBS???
Old Dec 6, 2001 | 10:22 AM
NEMISIS's Avatar
just like the title says..i need to know if the front and rear rims of a 300ex willl fir on warrior hubs?
ny help will be greatly appreciated..
thank
Old Dec 6, 2001 | 01:52 PM
54warrior's Avatar
No, at least the rear ones won't. The yamaha's have a 115mm bolt pattern compared to the honda's 110 mm. Not sure about the fronts.
Old Dec 6, 2001 | 01:59 PM
NEMISIS's Avatar
thanks 54 warrior ..
and im curious to know wut kind of tires you run on you warrior and what mods. you have on it. thanks
Old Dec 7, 2001 | 01:05 AM
54warrior's Avatar
On the front, I am using ITP Holeshot XC's size: 22x7-10's 6 Ply
Excellent tires. No punctures yet. Steer very well.
On the back, I am using GBC Shredders's size: 20x11-9's 4 Ply
Good tires at first with excellent bite, seemed to wear pretty well, but you end up with alot of flats due to sidewall punctures... should have gone with the 6 Plys.
As far as mods go, no suspension or motor mods YET. Just haven't had the $$$ to do that. I do have a PRM Belly Skid-Excellent quality, an AC Swingarm Skid-junk, I will never buy another AC brand product.
One of the biggest improvements is to install a 14 or 15 tooth countershaft sprocket. Inexpensive, and makes a big diff.
Good luck
Old Dec 10, 2001 | 10:19 AM
TitanRacing2's Avatar
the front rims will fit
Old Dec 10, 2001 | 11:52 AM
NEMISIS's Avatar
are you sure? b/ci wanted to switch the front rims..but i didnt want to spend the money if they wouldnt fit. are you 100% sure they will fit?
Old Dec 12, 2001 | 11:09 AM
i bought a set off of a guy for my 300ex, the guy said that they came off a warrior, and i'm pretty sure they work anyway, if you want, i can go get my buddies warrior rims and see if they'll work?
Old Dec 12, 2001 | 01:27 PM
NEMISIS's Avatar
i need to know for sure if they will work..b/c i dont want to spend the money and then have them not fit..if you could get your freinds rims abnd try them that would be great. thank
blueandy88
Sep 7, 2020 03:11 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
