Best 250R Reed Valves
Old Feb 4, 2000 | 04:11 PM
FourTraxXC's Avatar
Does anyone have any info on the best reed valves for the TRX250R? I have been leaning towards the new Moto Tassinarri Delta 2 after reading the test of it on the Banshee in Dirt Wheels. I also spoke with them and it sounds good. I just wondered if anyone had any experience with this valve, and/or any opinions on the best valve? Thanks Dave
Old Feb 5, 2000 | 12:25 AM
CT250R's Avatar
I heard some great things too in the chat about 2 days ago regarding the V force cage. I have always run the FMF ram valve witht the reed spacer(big difference when added). I like the FMF but I wish someone would buy all three and give us the real lowdown on this. Anyone out there have at least 2 of them to comparer head to head?
Old Feb 5, 2000 | 10:58 AM
JC TRX250R's Avatar
JC-TRX250R rides 1988 TRX250R with a LRD ported O-Ringed cylinder, Pro Design Coolhead, Delta V-Force Reed Cage, 40mm Lectron Carb, LRD Adjustable Team B pipe, 1985 ATC 250R clutch, Hinsen Adjustable counter balancer bearing holder, lightened flywheel, Black Moto Force race plastic, 21x7x11 Front Shredder, 18x11x8 Turf Tamers, DG front bumber,
I have tried fmf with and without reed spacer, RAD valve trx and cr with and without reed spacer and the V-Force. As u can see I stuck with the V-Force and sold the other 3. The V-Force had better acceleration then the Rad valve and more top then the RAM valve. This is the only reed cage that I will own now unless I buy one from Eddie Sanders Racing. They make the same thing expect theres is a little stronger constrution. I hope this helps.
Old Feb 5, 2000 | 04:58 PM
Bryon's Avatar
Where can i get one of these bumbers?
Old Feb 8, 2000 | 04:26 PM
FourTraxXC's Avatar
Thanks for the info, do you run a spacer with the delta valve?
Old Feb 8, 2000 | 09:14 PM
THREEX2's Avatar
I USE V-FORCE REEDS IN MY SNOWMOBILE AND THERE GREAT MUCH BETTER THEN BOYESEN OR FMF.
Old Feb 8, 2000 | 09:15 PM
THREEX2's Avatar
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
