need HELP with rev limiter.........
Old Dec 15, 2001 | 12:20 AM
rredriderr's Avatar
hey i have a stock 98 300ex and it runs great but here latley for about for first 30min the rev limiter kicks in a little over half throtal and it even does it longer when it is cold out and correct me if im wrong but to fix that wont i probley have to but a new cdi box because it is built in to it. and mine has a problem of throwing out rear end bearings to thanks for all ur help.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 15, 2001 | 12:31 AM
KILLER250R's Avatar
Do you road ride alot ? that will ruin your bearings real fast, if thats the problem then get a dule row bearing carrier or better yet a taperd bearing carrier. If thats not the case make sure the axlenut is really tight, if it's not tight enough you will have side to side axle slop and the side load is not good for your bearings.
As for the revlimiter It sounds more like a jetting problem seeing as it gets worse in the cold. Have you added a pipe or messed with the carb or airfilter or airbox ?? If so that could be your problem. I could be wrong but thats my thoughts.
Old Dec 15, 2001 | 12:02 PM
rredriderr's Avatar
yes i do ride the road alot and do u know how much one of those duel row bearing carriers are. and for the rev limiter i havent put a pipe,but i did get a new carb because mine was sticking wide open and i took it to the local dealer and they said i needed a new one but instead of getting a new one i decided to get a used one off a older 300ex. does anyone know whut jet to put in it.
Old Dec 15, 2001 | 01:33 PM
KILLER250R's Avatar
Thought so, the dule row carriers you can get one for about $170+ form LSR for the tapred it's like $220+
As for the carb if it's all stock try a 125 jet. It is REALLY bad to run it like this and it wil cause major engine trouble down the road if not delt with. If it still runs crappy try a 128 or a 120.
