250R'S
Old Dec 16, 2001 | 09:35 PM
Quadmaster24's Avatar
What parts from a 1988 250R will change over to a 86. Swingarm,A-ARM,Top end,fenders?
John Fahey 886
Old Dec 16, 2001 | 10:02 PM
HondaMan85's Avatar
I know the plastics will change over, and the swingarm on the 86 is either one inch longer or shorter, i can't remember. The a-arms are one inch further forward on one of them but im' not sure which one.
Old Dec 16, 2001 | 10:22 PM
KILLER250R's Avatar
86-87 Steel swingarms
88-89 -1 inch aluminum swingarms
86-87 A-arms regular
88-89 +1 inch forward A-arms
The swingarms I don;t think are interchangeable, the A-arms are interchangeable. Almost everything is interchangable on them.
Old Dec 16, 2001 | 11:31 PM
surethingtowin's Avatar
The swing arm is interchangeable, just like everything else.
Old Dec 17, 2001 | 04:35 PM
machwon's Avatar
The top ends are interchangable but the piston and cranks need to be the same year.
86 crank = 86 piston
87-89 crank = 87-89 piston
or 87-89 crank with 86 piston but must use spacer plate.
Old Dec 17, 2001 | 04:37 PM
ILoveHonda's Avatar
You can make any of it work.
Old Dec 18, 2001 | 09:25 AM
Dill's Avatar
the 88 swingarm will NOT fit on an 86 frame, unless you don't want to run the rear engine mount, as the rear swingarm mount on an 86 acts as an engine mount too.
Old Dec 21, 2001 | 05:01 PM
Warpig's Avatar
yes you can
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
