TRAILBLAZER PINGING
Old Dec 17, 2001 | 11:06 PM
TRAILBLAZERMAN's Avatar
I OWN A 99 TRAILBLAZER THE MOTOR IS 60 OVER HPD PIPE AND CLUTCH KIT
STOCK CARB IT PINGS AT 3/4 TO WIDE OPEN THROTTLE I HAVE A 165 MAIN JET. IT DOES IT AFTER I RIDE IT AT THIS SPEED FOR 50 TO 100 YARDS IM WONDERING IF THE CARB IS TO SMALL OF IF I NEED TO GO BIGGER ON THE JET PLEASE HELP THIS WEEKEND I PUT THE 165 JET IN AND IT STARTED TOPING AND LOSE POWER I BACKEDOFF THE THROTTLE IT STOP AND I GOT BACK ON THE THROTTLE AND IT PINGED JUS A SLIGHT BIT.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Dec 17, 2001 | 11:29 PM
CaptNemo's Avatar
Pull the sparkplug, If it's not a dark tan or brown, you're too lean and will burn the piston.
Also, since the bore is .060" over, I assume that you have a wiseco piston. ALWAYS LET THE ENGINE WARM UP BEFORE YOU RIDE HARD !!!!
Old Dec 18, 2001 | 02:38 PM
walexa's Avatar
You need to run premium grade pump gas as well. My Xplorer pings sometimes if I use 87 octane, so I changed to 92 minimum. Haven't had a problem with pinging since. Running lean can cause the same problem. Check into what CaptNemo suggested before changing over to premium.
Waylan
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
