Air box mod ???'s
Old Dec 16, 2001 | 02:55 PM
SpankyLowe's Avatar
OK I have a pipe and silencer for my trailblazer on the way thanks to Rick Ritter and was wondering about air box mods as I have seen you guys talking about...
What all is involved here,how do I go about it and does it make a differance ???
I will be getting a K&N filter next week so that will be taken care of but do you guys leave the pre filter and air intake tube on, maybe cut the tube down some to get better air flow and leave the pre filter off ???
Thanks 4 any info....
Old Dec 16, 2001 | 04:06 PM
trailblazerRIDER's Avatar
im not sure either but i got a stage 1 kit comin from rcr for my trailblazer!!!!! i heard it really wakes it up
Old Dec 16, 2001 | 07:38 PM
Muddyxplor4x4's Avatar
Air box mods are great and very cheap. Very simple install all it basically is a larger aluminum tube piece with a biger entrance for air that replaces your stock rubber piece, and then you add a 3rd hole to your air box, or get rid of it all together if you dont have to worry about weather and you will end up spending 15 for it all max, that is if you have k&n like you do
Old Dec 17, 2001 | 07:11 PM
SpankyLowe's Avatar
Does anyone have more info on this mod ??
Old Dec 18, 2001 | 09:30 AM
Quadfather's Avatar
The air box mod for the Scrambler is not applicable on the TrailBlazer. The T'Blazer has a totally different air box. All you can really do is cut off a couple of inches from the intake.
Old Dec 18, 2001 | 04:37 PM
SILVERHORSE's Avatar
Don't you need to change jet size when you mod the air box?
Old Dec 18, 2001 | 04:54 PM
After I re-jetted my Grizzly I popped the air box cover off just out of curiosity – it wasn’t a dog, but I couldn’t wheelie anymore. I suspect you would need to re-jet to a larger size to satisfy the engine’s new fuel requirements? I considered modifying the air box with multiple large holes which I could easily plug during deep water runs, but I think the jetting would need to be changed as well. Someone correct me if I’m wrong.
Old Dec 18, 2001 | 05:18 PM
You are correct, more air will lean it out a litte, you will have to re-jet 1-3 jet sizes, depending on what filter you use also. Like K&N.
