Adjusting Alignment
Old Dec 19, 2001 | 09:52 AM
fuddrucker's Avatar
Hey all, Had a crash a while back on my 98 Honda 300EX and after I replaced handle bars, I noticed the front wheels are out of alignment. The main steering shaft is not bent and it rides fine, but the wheels are out of alignment about an inch or two towards the right (if your are sitting on it). The manual shows how to REPLACE the tie rods (I beleive that's what they are called) but nothing about adjusting wheel alignment. I was thinking I could adjust the tie rods to pull the wheels back to the left a bit. Am I correct in assuming that adjusting the tie rods is how you adjust the alignment? If that is not the case, then does anyone know how, if any, to adjust the alignment?
Thanks in advance!!
Old Dec 19, 2001 | 10:35 AM
phaskell's Avatar
yes you do use the tie rods to adjust it but i might be that one of you rods is tweaked so i would check them out then replace them if needed
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
