Blaster Mods**Need Help Quick**
Old Dec 21, 2001 | 08:22 PM
MOJAVE02's Avatar
Ok I am picking up my blaster the day after christmas. here is what i plan on putting on it: FMF Fatty Pipe + FMF Powercore 2 Silencer, K&N Air Filter, Jetting, FMF Ram Valve, Boost Bottle, and I also want to change the front sprocket. what sprocket should i put on so I will gain more top speed, but not loose a lot of low end. Also what kinds of Top End Speed am I going to gain in M.P.H.?
Old Dec 21, 2001 | 10:52 PM
RdingManiac420's Avatar
Ok with yourmods you should hit around 56-58. Also I think tha stockgearing would probably be the best because if you change the front sprocket to higher gearing you will lose alot of low end.
Old Dec 22, 2001 | 10:53 PM
Blastermaster's Avatar
all that sounds good but wait tell your warrenty is up all that will void it also get a oil injector block off
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
