kaw 650 need help
Old Dec 24, 2001 | 04:41 PM
Zsilverado's Avatar
Just recently my prairie 650 started to make a not normal sound coming from the belt area or the I guess the belt brake sensor that sit on top of the belt cover. Well it makes a whistling TYPE noise till about 6mph then goes away till you drop the speed down below 10mph Then the noise comes back till I stop. So I took it to the dealer and was thinking it was the belt that was wore out so the dealer adjusted the belt and the noise is still there. The bike only has 340 miles on it and never made this noise before. Oh one more thing it will go the belt never does slip even before the dealer adjusted it so I don't think it could be the belt any one know or had this problem with there 650? the sound is driveing me crazy!
Old Dec 24, 2001 | 07:41 PM
TrailHog's Avatar
You know the sound that the 650 makes when you turn the switch off, mine makes that same sound sometimes riding slow or going down a hill, not all the time just sometimes. Is that the sound you are talking about?
Old Dec 24, 2001 | 11:47 PM
nyroc's Avatar
Trailhog, that sound you hear is just the engine brake. The KEBC or Kawasaki Engine Brake Control is actuated elctronically and you can see the motor for it on the top of the belt cover. The gearbox make a little whine, but I think the sound Zsilverado described is abnormal. I wish I could offer a suggestion, Zsilverado.
Old Dec 25, 2001 | 12:48 AM
Zsilverado's Avatar
YA I know the sound yall are talking about but this sound is not normal. I don't know I guess ill take it back to the dealer and see if they cant find out what it is and fix it the bike runs great no other problems just this bad not normal sound. "driving me crazy"!
Old Dec 27, 2001 | 05:08 AM
th41004's Avatar
zsilverado,i had the same problem,it is the bearing on the clutch cover that the ebc rides against. if you take the belt cover off you can feel the bearing and see if it feels rough. hope this helps.
Old Dec 27, 2001 | 03:55 PM
Zsilverado's Avatar
Thanks "th41004" ill try it and see if that's what's making the noise.
