Raptorette, First ride, Pix...
Old Dec 25, 2001 | 02:19 PM
fourlix's Avatar
Everything turned out great. First ride only lasted about a half hour, just 'cause it is friggin' cold here. I got the right springs for the front Works shocks X-mas eve. Spring rates are now right on. If I sit on it, my 210 lbs almost bottoms out the suspension's 6" travel front and rear.
.....I had been a little concerned that the wider and bigger rear tires would make it hard to turn. I was also concerned about the amount of caster I built into the A-arm mounts. I added 2 degrees to the stock Blaster geometry for a little extra stability at speed and in sand, at the expense of a little more steering effort. I also made the frame to accomodate 3 washers with the upper A-arm mounts, so I could dial in more caster later if we wanted to, like for a dune trip.
..... This baby handles like a dream. Totally neutral, and Ian has no trouble steering it. Right now it is stuck in first gear, with the throttle limiter EXTREMELY restricted. Top speed is about 6 mph.
I can jog alongside at top speed. We are learning about brakes. What stops Big Trains? Brakes. What stops Big Trucks? Brakes. What stops Big 4-wheelers?
......Raptorette First Ride
Old Dec 25, 2001 | 03:10 PM
TitanRacing25's Avatar
all ic an say is wow, i can only imagine how much fun he is having!!!
Old Dec 25, 2001 | 04:01 PM
SilverBear's Avatar
Fourlix~
Once again, that is an incredible machine, and I'm sure your child will have some serious fun on it. Good job..Yamahamma shoulda made the raptor that good.
SilverBear
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
