Honda 200X Questions Please Help!!
Old Dec 25, 2001 | 11:59 PM
FAST453EX's Avatar
I am looking at buying a 200x atc. What are the differences between the pre 86 models and the 86 and 87 models, some people have told me that one is a 6 speed and one is a 5. Others have told me the later models have more power and a 4 valve head. They are all manual clutch though, right? Is this as bulletproof as most old Hondas (my 82 atc 200 and 87 trx250 utility) ? Any help would be appreciated.
Old Dec 28, 2001 | 12:51 PM
krabill's Avatar
The 86/87 200x were much better, they have 6 speed instead of 5, more engine hp (might be higher comp piston?) they have some differences on the swingarm and axle, (its hard to find an 86 200x axle) they were white and blue, (they looked real good!) both are manual clutch. I have seen a lot of pre 85 200x's, they are everywhere. If you can find the newer one definatly go with that, I may be a collectors item someday, never know. reliability is good, excpt mine sits with a locked up engine. I let a friend use it and the oil never got checked for a while. they will run strong (as long as you keep oil in it!) I have a new 86 engine on the way from ebay right now. I believe that this is the eaisest bike to wheelie and keep balanced. thats all
l8r
91 TRX350X
85 ATC250R
86 ATC200X
94 CR80
Old Dec 28, 2001 | 04:13 PM
Mr350X's Avatar
I had an 84 for a while. It was strong, and like krabill said, the most wheelie-able bike ever. (exept my 350X) Fun bikes. The guy who bought it, rode it first and said it felt faster than their 300EX. strong runners indeed.
Old Feb 13, 2002 | 01:02 PM
james200x's Avatar
I have a '85 200x that I just bought, I want to juice it and was wondering if a 440 big bore kit would work for my machine, and what mods would have to be done. If not any suggestions on power/speed would be greatly apprieciated.
Old Feb 13, 2002 | 03:36 PM
AlaskaYFM's Avatar
If you want to bore out your 200X, james200X, you are just asking for trouble. The ATC200X engine (which is almost identical to the XR200 engine) loses reliability exponentially once modifications are done to the engine. Sure, a mid-range cam or little bit higher compression piston won't hurt, but anything serious and then you have a time bomb on your hands. Keep the 200X engine stock, the little trikes are good trail machines but not much more.
FAST453EX- there are a bunch of differences between the '83-'85 and '86-'87 200X trikes. Besides the 5 vs 6 speed gearbox, the '86-on machines have a different swing-arm, shock, bearing carrier, axle, frame, and forks. Basically, the '86-on machines have new rolling chassis with almost the same engine. Oh yeah, different plastic and seat, too. The '86-'87 200X trikes handle a little bit better than the older models, but they still have that same 200X feel that every trike rider loves.
Old Feb 12, 2003 | 08:11 PM
FISHBAG's Avatar
Default Honda 200X Questions Please Help!!
Old Feb 13, 2003 | 12:54 AM
mojave300ex's Avatar
Man those thing are pretty fast for a little 200, I raced one on my 300ex and got him off the line every time but he would burn me on top-end they must run 60+ do they come stock with twist throttle this one had it and he said it was stock
Old Feb 13, 2003 | 09:33 AM
dzzy's Avatar
AlaskaYFM nailed that one right on. The 200x bottem end is a hand grenade with too much mod, not to mention all the clutch plates you'll be going through
Old Mar 19, 2015 | 01:01 AM
andresmibo's Avatar
Default need some help wt a four weeler in argentina
- i can see you know a lot of the honda atc engines, i personaly have an 4weeler with the body of a 250 and the atc 200x engine from the 86 tribile, i thik they sold it just in argentina where im from or in Mexico also, it says made in Mexico.... Te thing is i cant find the camahaft or the rocher arms
Y realy need the camshaft coa the old owner used it witout the oil pump worquing... If u can help me i reeeeealy apriciate it... Greetings from the south :-) QUOTE=krabill;346150]The 86/87 200x were much better, they have 6 speed instead of 5, more engine hp (might be higher comp piston?) they have some differences on the swingarm and axle, (its hard to find an 86 200x axle) they were white and blue, (they looked real good!) both are manual clutch. I have seen a lot of pre 85 200x's, they are everywhere. If you can find the newer one definatly go with that, I may be a collectors item someday, never know. reliability is good, excpt mine sits with a locked up engine. I let a friend use it and the oil never got checked for a while. they will run strong (as long as you keep oil in it!) I have a new 86 engine on the way from ebay right now. I believe that this is the eaisest bike to wheelie and keep balanced. thats all
l8r
91 TRX350X
85 ATC250R
86 ATC200X
94 CR80[/QUOTE]
Old Mar 21, 2015 | 08:16 AM
brain21's Avatar
it's very helpful... i have same case
Cole Hadden
Jun 15, 2025 09:05 AM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
