Wolverine Bearings
Old Dec 26, 2001 | 09:59 AM
Camo-man's Avatar
My front bearings are shot....Can I go with a sealed bearing
on a 97 Wolverine????(front) Will they overheat?????
What is the trick to getting them out, to get numbers for bearings...
Thanks.....
Old Dec 26, 2001 | 11:26 AM
95wolv's Avatar
Hi,
I replaced the wheel bearings in my 95, it isn't the most fun I've had,but it is easily done in the garage. The bearing is a 6006 2RS(2rubber seals) you will need 4,and a good punch to get the bearings out,be careful not to nick the housing. I made a plastic driver to make sure I drove the new ones in straight,make sure what ever you use,like a socket,or piece of wood,only hits the outside ring,or you risk damaging the new bearing. I went to the Yamaha dealer for the bearings- 25 bucks a piece, got them out of Dennis Kirk for less than 8 bucks. A bearing or tools warehouse might even have them cheaper. I also carefully took the seal from the inner side of the bearing and packed them full of grease,not a lot from the factory. I also made sure the axle housing was packed as full as possible,to keep moisture out and provide as much lube as possible. Also,keep an eye on all the seals,there is a little oring that is easy to lose.
Old Dec 26, 2001 | 11:37 AM
Camo-man's Avatar
Thanks......
Old Dec 26, 2001 | 05:29 PM
macgiver's Avatar
i bought sealed bearings for 9 bucks each from a bearing company. have not had a problem. they do get a lot of use.
Old Jan 8, 2002 | 01:30 PM
Briand's Avatar
I recommend NTN 6006LLU bearings for the front, they may cost a bit more but they are worth it. Had mine in for a long time and no problems so far... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 8, 2002 | 01:50 PM
Camo-man's Avatar
I can't remember the exact numbers on the bearings , but I got sealed
6006's manufactured by ***...they were approx 15.00 each,,,seals
were 5.00 for outside and 6.00 for inside.....will change the other side
this weekend......
Old Jan 13, 2002 | 01:22 PM
MattDewalt's Avatar
I now need to replace front and rear bearings in my 95 Wolverine. I've looked through many aftermarket catalogs such as Rocky Mountain, Chapparral, and Dennis Kirk. I can't find a listing anywhere. I hate to pay the dealer their premium price. Anyone have any ideas on where to get them?
Old Jan 13, 2002 | 05:36 PM
SpDdEmOn's Avatar
When I was in your position not too long ago I just took the old berings to the dealer and had him match up the numbers and get me aftermarket berings. The dealer wanter $14 apiece for the berings and I ended up getting them for $8 apiece and they were sealed and better berings.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
