second battery for accessories?
Old Dec 26, 2001 | 11:28 PM
tmbk2's Avatar
Is there a tried and true method to adding a second battery power supply for accessories such as a winch, back up light, spot light etc. I have a 2000 RSE sp500 that could use more electric power. I have seen posts where people have incorporated the polaris 500 diesel method? If this is the answer, I could use more info. If there is another solution that has worked well for you, please let us know.
Thanks!
Old Dec 29, 2001 | 06:36 AM
500DUSE's Avatar
I know somebody's done this,???????????
Old Dec 29, 2001 | 12:36 PM
uflg95's Avatar
I use the diesel setup in my Sportsman and love it. It costs $100.85+tx without the battery and $180.60+tx with the battery. Now this is using all the OEM parts so if need be for a lower cost you could probably cut some corners. I used all OEM parts on mine for a real clean look and for selling purposes at our dealership. I have seen cheaper ways that work just as well.
Old Dec 29, 2001 | 12:57 PM
SHAGGY500HO's Avatar
uflg95
How long will these parts be available? The diesel was dicontinued right. What parts do you get for $100.85+tx.
Old Dec 29, 2001 | 01:07 PM
500DUSE's Avatar
What do you mean by the diesel set-up??
And where will the battery go?
Old Dec 29, 2001 | 03:20 PM
uflg95's Avatar
The battery will be located directly under the tool box. You can look at the parts manual for the diesel on the Polaris web site to get a better idea. You will get every piece that is used on the diesel setup including the strap, 2 hooks, + cable, - cable, retainer, 4 bolts, 4 washers, 4 nuts, 6 pads, battery box, bottom pad, tool box (not as deep as original so battery will fit), and 2 bolts. Sounds expensive but it makes a nice clean look.
Old Dec 29, 2001 | 05:02 PM
modquad's Avatar
You can also contact Ricky Stator (back of Dirt Wheels or ATV Sport) and have your stator re-wound for around $75 for increased output.
Ken
Old Dec 31, 2001 | 11:22 AM
tmbk2's Avatar
Thanks for the suggestions guys. I will make a trip to the dealership and see if hey can order a Diesel set up. If anyone else has another set up, please advize before I drop all that cash...
Old Jan 1, 2002 | 02:55 PM
tmbk2's Avatar
Thanks again guys. uflg95, I went to the dealership but with all of the new snow, they are very busy with sleds and making lots of $$. No time for my little questions. I was wondering, for a quick fix, what size battery, name brand etc did you use for the diesel set up and if I just bought one of those, how do I wire it up? I have a nice custom tool box off my rear rack that I could drop the new battery into and get buy until I can order those expensive OEM parts. Is there a better or bigger battery that I could use instead of the small OEM diesel one. How about just adding another standard battery?
Happy New Year!
Old Jan 1, 2002 | 08:51 PM
StockSPHO's Avatar
Is it possible to install the Sportsman 700 "Big battery" behind the airbox on the 500? And would this be a better and cheaper way to go?
Just asking?
Mark
