second battery for accessories?
Old Jan 2, 2002 | 01:27 PM
uflg95's Avatar
I can relate with being busy with snow, we are swamped. The 700 battery would work, it and the diesel battery are both 30 amp. The diesel battery is not as expensive as the 700 batery by $20. Any battery would help it doesn't have to be one of the above mentioned. Like I said you could save a lot of money if you built your own battery box but I chose the OEM style for looks. The batteries are hooked up in parallel.
Old Jan 2, 2002 | 08:26 PM
tmbk2's Avatar
Thank you. I appreciate the rely.
Old Jan 2, 2002 | 08:55 PM
StockSPHO's Avatar
What I was trying to say was, the 700 battery looks a lot bigger then the 500 battery. It is also located center mass behind the air box. Is this a easy add on?
Just asking?
Mark
Old Jan 2, 2002 | 09:39 PM
uflg95's Avatar
StockSPHO, yes it is fairly easy to add on. I do not know exactly where the 700 battery is located. I know the diesel battery is located in the center directly behind the seat latch under the tool box. I could have just used the diesel battery and not the stock one but I figured 2 is better than one! The diesel battery is fairly large itself. I will have to check the set-up out on the 700 next chance I see one. No matter how you do it you will not regret it, for my winch it made operation and power night and day.
Old Jan 3, 2002 | 12:20 AM
  #15
DoubleBoss's Avatar
Tmbk2,
Any chance you went to the Alpine dealership?!!
Old Jan 4, 2002 | 11:18 PM
  #16
tmbk2's Avatar
yep...
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
scram5050
Sep 3, 2015 05:06 PM
