How much octane is too much ???
Old Dec 30, 2001 | 01:15 AM
SpankyLowe's Avatar
I'm in the process of putting my pipe on and rejetting my TBlazer and seen that in the instuctions it said to use at least 92 octane gas and was wondering if i could use higher octane than that and if i do use higher than that will i benefit from it or am i just wasting money ??
If i do use a (race gas) will i be doing damage to my motor down the road ?? what are the down sides to using higher octane ??
Old Dec 30, 2001 | 01:48 AM
kukerdan's Avatar
you need a highcompression piston and/or new head to run anything over 86 octane
Old Dec 30, 2001 | 02:23 AM
RickRitter's Avatar
On Spanky's 250 aircooled polaris 92 and up fuel is a wise idea . The design of the head and aircooling mixed together make the engine prone to pinging especially with an aftermarket pipe .
An aftermarket pipe will raise compression in an engine due to the pulses being timed perfectly with an engines strokes . This will not be noted with a compression guage but at operating RPM's it happens .
In a nutshell , follow the instructions .
Higher octane won't hurt a bit . I have never found a octane booster that has really been effective, (If you have one send me some ) 91 or 92 octane will be fine , if you would ever need more , start mixing race fuel in with pump gas , that is the only thing I have ever seen work well .
I realize there are issues with specific gravities on race fuels when combined with pump gas but I have been successful combining the two like so many others .
Old Dec 30, 2001 | 11:43 AM
kukerdan's Avatar
my bust, i meant to say 96* not 86, lol, i run 94-100
Old Dec 30, 2001 | 02:39 PM
Lurch77's Avatar
Also remember that having more octane then required to stop pinging or knocking will start to degrade performance in some cases.
Polaris-400
Aug 19, 2015 02:20 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
