Help... how to drain gearcase oil..
clutch cover side of transmission bottom side of trans you will see a bolt that extends abouta inch and ahalf out touching the frame turn that bolt in in order to get the plug that it is threaded into out then it will drain there is a magnet at the end of the plug after its drained just reverse the proceedure
