Raptor axle nut tightening technique
The Raptor service manual describes the following sequence:
1) Tighten inner nut to 40 ft lbs.
2) Tighten outer nut to 140 ft lbs. while keeping inner nut from turning.
3) "Tighten back" INNER nut to 170 lbs. while keeping the outer nut from turning. Basically tighten inner nut against outer nut which effectively loosens it somewhat from up against the brake rotor hub.
Everyone that I have asked has said just tighten the crap out of the inner and use the outer as a jam nut. This is basically reverse of what yamaha intends.
What do you guys do ?? Any thoughts on this one ??
Thanks
Thanks
Fisher,
That factory procedure is correct! Only problem is that once you back lock the nuts, you will need to drill and split them to get them off. If I have a bike where the nuts are a problem, I will use that procedure; however, on the other bikes, I simply use locktite and mark the nuts with a stripe of finger nail paint (much easier to service).
Hmmm....mine did come loose (the brake rotor had play) so I tightened ther nuts per the yam instructions. Motion pro makes a nice two wrench set for this (only $35). Do you expect this is going to be an on-going battle ?
Another question - I have never had an aftermarket axle - are there similar axle nut issues with these ?
Thanks, Eric
Thanks, Eric
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Elkaholic
Sep 6, 2015 02:44 PM
